    Welcome to the #1 Audi RS3 Forum and Audi RS3 community dedicated to Audi RS3 owners and enthusiasts. Register for an account, it's free and it's easy, so don't hesitate to join the Audi RS3 Forum today!
rattly rear seat
Storme
New member
Reactions
1
WIMBORNE
Non-US
United Kingdom
S3
what is the best way to stop the rear seat from rattling
my rear seat(drivers side) just rattles badly
if i undo the seat, from the clip, and let it hang down, it is silent
can they be adjusted to clamp better ? or just put some high density foam there to "make" it clamp tighter
J
Johnny
Guest
#2
What do you mean "hang down"? Isn't the seat on the floor already?
OP
S
Storme
New member
Reactions
1
WIMBORNE
Non-US
United Kingdom
S3
Thread Starter #3
the rear of the seat is in an upright position, if you unclip it from the catch at the top, it hangs down, or lies almost flat on the the actual seat
J
Johnny
Guest
#4
Inspect the clip and the back of the seat closely with good lightning. Something may be loose or there might be adjustment screws to tighten the hold.
Also, compare it to the other seat.
92683
Moderator
Staff Team
Reactions
46
socal.
CA
United States
2015 s3
#5
sounds like you didnt push it back all the way to clip into the latch.
for me when i need to put them back up, i slam them into the latch. literally slam it! it wont break anything. be forceful.
it will then lock into place.
try that method and get back to us here.
J
Johnny
Guest
#6
Any update on this?
OP
S
Storme
New member
Reactions
1
WIMBORNE
Non-US
United Kingdom
S3
Thread Starter #7
the seat is back correctly, and slammed a few times !!!
i have put some high density 25mm wide, 20mm thick foam near the clip.. this makes a constant push back on the back of the seat, which keeps the clip "gripping" the metal catch.
also taken out the parcel shelf, which makes a huge difference !!!
i intend lining the parcel shelf area, the bits that touch the plastic, with sticky back felt
BB Golf R
New member
Reactions
Somerset
NJ
United States
2024 Golf R
#8
Had the same problem with my MK7.5 GTI The dealer had to replace the latch which solved the problem for about a year. When the rattle returned i wrapped electrical tape to the pin mounted to the body side. Problem solved.
OP
S
Storme
New member
Reactions
1
WIMBORNE
Non-US
United Kingdom
S3
Thread Starter #9
yes, thats a good idea..i seem to remember doing the same on my old mk6 golf
thanks
i might even make a small thin plastic sleeve at work to go round the pin
OP
S
Storme
New member
Reactions
1
WIMBORNE
Non-US
United Kingdom
S3
Thread Starter #10
the tape has worked :)
