Air Suspension issue
Broady
New member
Reactions
Lower Dicker
Non-US
United Kingdom
A6 Allroads
Can anyone advise. My Audi A6 Allroads 2012 has developed an intermittent problem when stationary. The rear left side suspension drops down making it look like there is an air leak. Sometimes both rears go down.
This only happens when the car is left for a few hours. When I return to the car and unlock the car with the key fob and open the door the suspension rights itself. When I go into IMI system to vary the height settings
I have limited settings only position 2 and 4 then it clears and all settings work? Could it be the compressor or the valve block. Or one of the suspension struts air bags or even air lines. Has anyone come across this before?
