Pure White Timeline - Project Talltrack V2
Reactions
9
Greetings! As I have done with every other vehicle I have had, I am starting a timeline thread to help me keep track of progress. I am coming out of a 2017 Alltrack S manual that was totaled in August 2018 by a 26 year old girl running a red light.
OP
T
Reactions
9
Thread Starter #2
Information
Vehicle Information
2018 Volkswagen Alltrack S
1.8T (170 hp | 199 lb-ft)
Six speed manual gearbox
Purchased from Young Volkswagen in Easton, Pa (22 September 2018)
LC9A Pure White
Current Odometer
61,500 miles
Drivetrain
  • S&B intake
  • OEM intake block off plate (5Q0-129-849)
  • OEM IS20 turbo
  • DBV2 turbo inlet pipe
  • United Motorsport engine tune (IS20 file)
  • United Motorsport Haldex tune
  • Burger Motorsports intercooler
  • Sachs Performance clutch and pressure plate
  • Sachs dual mass flywheel
  • AWE Tuning Touring cat-back
  • AWE Tuning 90mm exhaust tips
  • Clutch delay valve removed
  • ECS Tuning boost tap
Interior
  • OEM European light switch
  • OEM switchable hatch light
  • OEM auto dimming rear view mirror with Home Link installed, calibrated, and programmed
  • SiriusLED 3020 36mm festoon LED hatch bulb
  • OEM warning triangle in rear hatch
  • Burger Motorsports short throw clutch stop
  • OEM LED footwell in glovebox
  • ECS Tuning hatch struts
  • DIY hatch release button
  • P3 Gauge analog gauge with vent
Exterior
  • OEM European[/URL] aspherical mirrors
  • OEM power folding mirrors
  • OEM bumper guard
  • OEM base carrier bars
  • Klii Motorwerkes door decals
  • Thule Canyon 859 roof basket (shared with wife's R32)
  • Curt 114223 Class 1 Trailer Hitch
  • OEM trailer module and wiring
  • Lamin-x yellow fog lamp film
  • Lamin-x clear head lamp film
  • Opti-Coat Pro+
  • Opti-Glass Pro
  • Opti-Metal Guard on exhaust tips
Lighting
  • BEC Autoparts Golf R Headlamps
  • Head lamp leveling kit
  • Morimoto 5500K HID kit
  • Hella Optilux H11 yellow fog lamp bulbs
  • OEM European tail lamps (dual rear fog) with The Bearded Detailer adapter harnesses
Suspension
  • Bearded Elevation System 1" lift kit (BES1)
  • Firestone 4175 Coil-Rite Air Helper Spring Kit
  • EMD Auto rear sway bar
Wheels
  • 42 Draft Designs 15mm spacers (rear)
  • 42 Draft Designs 45mm bolts (rear)
  • MSW Type 85, 16” x 7.5”, et42
  • Nokian Rotiiva, 215/65R16 102T
  • OEM VW valve stem caps
Brakes
  • G-Loc GS1 pads
  • Textar rotors
  • Motul RBF600
  • OEM RS3 brake vent ducts
VAG-COM
  • VCDS: fog lights on with high beams
  • VCDS: instrument needle sweep
  • VCDS: driver seat heated seat retention
  • VCDS: passenger seat heated seat[/URL] retention
  • VCDS: off road menu activated
  • VCDS: passenger mirror dip with reverse
  • VCDS: remote windows open and close
  • VCDS: disable seatbelt chime
  • VCDS: disable door open/ignition chime
  • VCDS: DRL as option on MIB
  • VCDS: high beams and fog lights flash[/URL] together
  • VCDS: hatch open with remote
  • VCDS: rear fog light enabled
  • VCDS: single-sided parking lights
  • VCDS: rear turn signals on with hatch open
  • VCDS: correction for larger tires
  • VCDS: longer delay of rear wiper
  • VCDS: fade in and out of interior back lighting
States Visited
  • Connecticut
  • Maryland
  • New Jersey
  • New York
  • North Carolina
  • Pennsylvania
  • Rhode Island
  • South Carolina
  • Tennessee
  • Virginia
OP
T
Reactions
9
Thread Starter #4
To Do List
Listed are the parts that I want to purchase and add to the Alltrack. If it is red, then it has been ordered. If it is blue, then it is in my possession.
OP
T
Reactions
9
Thread Starter #5
Present and Past Vehicles
The vehicles that have been with me along the way. There are more but these are really the only ones worth mentioning.
My wife's 2008 .:R32
My old Alltrack - totaled
My A4 - traded
My Passat 3.6 - traded
My GLI - totaled
My Jetta Coupe 2.0 ABA - sold
My Beetle - sold
OP
T
Reactions
9
Thread Starter #6
I realize that I have not been on here in a while so I will only do two updates regarding lighting. I recently wired up the leveling motors in the BEC Autoparts headlamps to an OEM European dimmer switch, which has a second roller specifically for moving the head lights up and down.
I tried to make them as plug and play as possible but sadly there is no mating connector to the factory dimmer switch connector, so I simply removed the pins from that and plugged them into the European connector. Not that difficult thankfully. Now the lights can be moved up and down depending on the load in my hatch right from my dash.
View: https://youtu.be/8hpx56ONjV4
Next, I installed OEM European LED outer tail lamps since I already had the driver side inner for a rear fog. The hardest part was getting the coding correct which I am not happy with. Instead of the parking lights being used during the single sided parking lights, I coded the turn signals to fill this role.
View: https://youtu.be/gtHD5SeLRmg
Other than that, I am just driving and enjoying the car. Just rolled over 10,000 miles this weekend and I will be changing the oil today. I do need alignment soon and before I do that, I will be upgrading the rear shocks to Atlas shocks. The Opti-Coat Ultra clear bra is here and I just need time to install it and coat that.
AlltrackMike
Active member
Reactions
4
TX
United States
#7
Anymore updates on this?
AlltrackMike
Active member
Reactions
4
TX
United States
#8
Mike if asking me, I'm deferring to Chris as its his thread, of course-
But jumping in with an edit on question to Chris:
- my bad, I meant to ask-"how are the Firestone airbags holding up? "
Sorry I was asking the OP lol.
OP
T
Reactions
9
Thread Starter #9
I'm sorry for the lack of posts. I used to be really good at forum posting but I guess I have lost that skill, hah. Since February, I guess I have accomplished a few things.
I sold the steel wheels and got MSW Type 85, 16” x 7.5”, et42, and I am just running 15mm spacers in the rear. I just transferred over the tires from the steelies.
I ditched the CTS intake and picked up an S&B intake and while it takes up a lot of room, I noticed a difference in fuel economy and I got rid of the unnecessary noises. I also added an OEM block off (5Q0-129-849) to the rad support which forces more air to the intake.
I finally bought power folding mirrors, which I had wanted since buying my first Alltrack. The memory function of the passenger dip is coded to work properly too.
After a lot, and I mean a lot, of research, I was able to wire up an OEM trailer module so that when I plug in a trailer, the ABS module compensates with braking and stability. It also will tell me if I have a trailer light out on the car display. There are a lot of added bonuses to this and I need to get off my ass and write it all up for others to be able to do it as well.
Lastly, I drove to South Carolina just to pick up a set of SEL seats, front and rear. My wife had been complaining about her back on long trips and this was a pretty good deal, minus the 1,400 miles to drive and get them. I had to make adapters to make them plug and play because they were out of a 2015 TDI wagon but again, worth it.
For those asking about the lift kit, a second run is happening and in production currently. Hoping to be able to ship them before Christmas. The first batch of 20 kits has had only one negative review from a person that I will say was not a very stable or reasonable person that did not want my help. My kit is the prototype and is still holding up just fine with almost 40,000 miles on it.
OP
T
Reactions
9
Thread Starter #10
Oh, on my way home from South Carolina with the seats, I made sure to swing through the Tail of the Dragon. Lift kit, rear sway bar, and 30 psi in the rear assist bags helped with the full car around the turns.
Reactions
1
#11
Sweet update! Any noticeable difference with the S&B intake?
OP
T
Reactions
9
Thread Starter #15
Good morning!
Not much new to report with the Alltrack. The IS20 installation went smoothly and I soon after replaced the JB4 with United Motorsport IS20 engine tune. While the JB4 was a good tool and bought me time, it was always intended to be temporary. The stock clutch has been holding up perfectly fine and the car finally feels exactly what I have been hoping for. Towing has been effortless!
Not many plans on the horizon. I will need new tires by the end of summer most likely. The Nokian Rotiivas have about 52,000 miles and still say 40% on the tread but I don't think I want to go into Winter with that or less. We shall see.
I did replace the stock pads and rotors since the rotors were pretty grooved and slightly warped. I went with Textar rotors and G-Loc GS1 pads. By far my favorite street/performance pad that I have run on the R32 and for towing this was the route I wanted to go, pair with Motul RBF600 and Neuspeed stainless steel brake lines. Fantastic pedal feel and good cold bite without any hot fade.
Reactions
3
Middleton
WI
United States
2019 Alltrack
#16
Thank you for the update @thebeardeddetailer . It's fun to see all the possibilities.
My car is only a month old and a 2019 with the bigger wheels and electronics upgrades. That sort of eliminates wanting to do some upgrades but your list is inspirational. So far I added a hitch and did window tint. Also the interior liner with seat back protection.
Your mods done via VCDS interest me. Do VCDS and OBDeleven do much the same thing? Your fog lights on with high beam and fog lights on with light flash interest me. Is the mirror dip in reverse available for all versions of Alltrack?
Thank you.
slgoetz
New member
Reactions
Brooklyn
NY
United States
AllTrack 2019
#17
@thebeardeddetailer how hard was it to install the "DIY hatch release button". What kit did you use?
Love the updates, killing it.
